I'm a recent convert from Nikon. I was using the Nikon D750 with a Sigma 150-600 mm and 1.4x teleconverter for lunar photography. Now, I have the Sony A7M3 and expecting to get the 70-300 mm FE lens soon. 300 mm is a little short for lunar photography.
Does anyone have any lunar photographs taken with a Sony full frame camera and any lens?
John
See this:
A9, 100-400GM plus 2.0 TC  - no crop.
Edited by Chrissie
  • 6 months later...
This was digiscoped with a Swarovski STX85 Spotting Scope w/ 25-60X Eyepiece, Sony a7III w/ Zeiss 35mm f/2.8, and Digidapter(r). EFL~1300mm.
