SO when I got the camera I was charging it over USB, for some reason that stopped. I don't know if I messed up a setting or if there is an issue.
When I plug in either the usb-c or micro usb if the camera is on it will just give me the message "USB Mode Connecting". If it is off it doesn't do anything. I seem to remember a light being on when charging. Either way I left it over night and it did not charge.
The setting in the menu setup4 > USB power Supply is on.
Is the camera turned off when you connect the USB for charging? According to the manual the camera should be off when connecting it to power. If you want to use the camera it will power via USB but won’t charge the battery.
