Hello!
4 years ago I filmed timelapse with the Sony A77 and Sony A65 cameras. Final material was built in a format 4K. For many reasons open access in the maximum quality to this video I could just now.
Please rate the video. But consider that I did it in far 2013  ;)
  • 4 months later...
