Hi everyone,
Just joined the forum and this is my first post! Last summer I shot a whole bunch of footage with a borrowed Sony A7R II and a Soligor 135mm f/2.8 T-mount lens mounted via a T-mount to E-mount lens adapter, and here's the finished product. I made a couple rules for myself on this one: only static shots, compose the subject to the center and try to only capture images that personify summer. I wanted the footage to look like 16mm so I added HolyGrain 16mm grain in post. This was a highly experimental project, but I feel like it turned out pretty well. Let me know what you think!
https://www.youtube.com/watch?v=hxGB3Nw3GCM
