Does anyone know of a manufacturer making a tilt/shift adapter that would use Hassleblad/Fuji XPAN lenses.  The image circle is well over 65mm, and the lenses are outstanding and very small for being medium format in coverage (90mm f4 is smaller than FE 50/1.8).  I am surely not the only one to think of this.  It would make an extremely small and light landscape & product setup that would provide a tremendous level of technical camera/lens movement.
Shouldn’t be hard to get Kiron to make it since they already make an XPAN to E adapter, just not the T/S version like they do for Nikon F, Olympus OM, & C/Y
Why not just adapt the N/F version to your E-mount body  ?
That possibility is prolly the reason they don't feel obliged
to build a version direct-fitting to E-mount. Like ... doesn't
EVERY [geeky/techie/advanced] E-mount user already
have a N/F adapter in use already ? Acoarst they do :-)
Not sure what you are talking about since there are no XPAN to Nikon F adapters since the registration distance on XPAN is about 12mm shorter than Nikon F, hence no adapting them with a Nikon-E adapter, unless you are only shooting macro, and I specifically stated this would be for landscape and products.
 (You can get an N/F lens to XPAN mount adapter, but why would you want to put a big clunky and inferior uncoupled 35mm Nikon lens on a 65mm image circle rangefinder body via an adapter? Makes no sense)
Nikon F T/S lenses are large/heavy/expensive/scarce and not able to offer the same image circle or movements, and are overpriced for the optics. Canon EF T/S glass is good, but large, heavy and overpriced as well.
Nikon F lenses, or any other conventional 35mm lens via a T/S adapter are unsuitable due to the fact that they will not cover full frame once any lens movements have been made. They only work for APSC.
A direct E-XPAN T/S adapter is the only way to make it work, and would offer superior performance, size/weight, and value vs. other options.
  • 1 year later...
    • Hi. tried this one. I have the same problem and read your post. I tried everything until this. it worked.   LuckySn0wMan •4mo ago•Edited 4mo ago   I've just had exactly this issue recently on my Sony A7r2 and successfully resolved it. I bought this camera used, so looks like the previous owner of the camera tweaked it's firmware to unlock additional languages. These tweaks caused this issue after the camera spent significant amount of time without the battery installed. Note that on ny camera the OpenMemories tweak app is not installed, so I used the pmca-gui PC application to change tweak settings of the camera firmware without the OpenMemories in camera app. So my sequence of actions to fix the camera: Install the battery. Connect the camera via micro-usb cable to your windows bases PC. Power on the camera. It should start in mass storage mode. Download the pmca-gui-v0.18-win.exe executable from the official github page: https://github.com/ma1co/Sony-PMCA-RE/releases. On the Camera info tab press the Get camera info button just to test that the app can successfully detect the camera. Go to the Tweaks tab. Press the Start tweaking (updater mode) button. The Updater mode tweaks tab should popup. Camera display will be completely black and the buttom right LED will be on. Select the Unlock protected setting checkbox. Uncheck the Unlock all languages checkbox. Uncheck the Unlock protected setting checkbox. Press the Done button. Once the app applies all changes to the camera firmware, exit from the app and power off the camera. After power on the camera should start working as usual. As additional info: My camera had the following tweak settings during the gray screen problem: Disable video recording limit: not selected Unlock all languages: selected (possible cause of the bug) Enable PAL/NTSC selector & warning: selected Enable USB app installer: not selected Unlock protected settings: selected After my changes that helped to fix the camera power on gray screen: Not selected Not selected Selected Not selected Not selected
