Maki85 Posted December 2, 2016 Share Posted December 2, 2016 Hi there There is no disscusion place for flash photografie... Link to post Share on other sites More sharing options...
Advertisement Posted December 2, 2016 Posted December 2, 2016 Hi Maki85, Take a look here flash. I'm sure you'll find what you were looking for!
Username Posted December 4, 2016 Share Posted December 4, 2016 Hi there There is no disscusion place for flash photografie... Have you run a forum search for threads on flash ? I've seen almost none. This would explain why no special subforum exists for it. Creating a subforum does NOT create interest. You need interest first. Over at the PhotoCamel forum there is a subforum for lighting and flash. While it would not be specific to Sony, users DO ask brand-specific and system- specific questions ... altho answers/solutions for the Canon/Nikon users are reliably offered while Sony related questions may or, more like may not, result in a solution being offered. This is cuz Sony has a much smaller user base in general and also cuz the Sony system is so poorly user-integrated that even if the user base were larger, even if it were huuuge, solutions to problems cannot be offered where the problems are [very Sony-typically] intractable :-( Sony makes very fine compact and versatile photo gear, but has approximately zero understanding of the users of photo gear. Sony gear has advantages and it has annoying shortcomings. You pays your money and you makes your choice [of brand], and the choice of Sony is not the wisest for all users. ######################################## OTOH, in today's flash and lighting gear market, the inmates are running the asylum and the asylum staff seem to be self-medicating and joining the inmates. This is not a Sony-specific problem. Flash is a very simple thing, but is math-related. Math is SCAREY, even rather simple math. Users FEAR math, and so a hornets' nest of unnecessarily complex solutions arose to HIDE the math. Unfortunately, the solutions are worse than the imaginary, fear-driven "problem". *Atteetood engaged* Now that Everything-Anyone-Needs-to-Know-About- Flash-Photography has been posted, right here right now, there is no actual need for a "Flash" subforum :-) YMMV ... but, so what. *Atteetood disengaged* Link to post Share on other sites More sharing options...
jamescooper Posted December 6, 2016 Share Posted December 6, 2016 As long as I am seeing there is no discussion on flash photography here. Link to post Share on other sites More sharing options...
aeonsakura Posted December 8, 2016 Share Posted December 8, 2016 any recommendation for sony a6000? Link to post Share on other sites More sharing options...
KMG Posted December 8, 2016 Share Posted December 8, 2016 aeonsakura, I doubt anyone here would give you a recommendation without more detail from you. I suggest you provide more information such as (off the top of my head): -why you feel you need a flash beyond the pop-up one on the camera; maybe a more powerful fill flash for on camera? -do you only want a Sony branded flash or are you open to 3rd party flashes? -what are you trying to accomplish with a new flash; off camera flash?; control other flashes from a flash mounted on camera?; etc. -what is your budget? -do you want fully automatic (TTL) or are you comfortable with manual? -Is size and weight important to you? More detail on why you ask would allow members to provide you with educated suggestions. KMG Link to post Share on other sites More sharing options...
Dollanganger Posted December 15, 2016 Share Posted December 15, 2016 After a lot of research I chose the F43m (NOT the “F43am”) This flash far surpassed all of my expectations. It does far more than any other flash on the market and does it really well! It took shooting non stop for THREE HOURS at room temperature to get it over heated. I simply replaced the hot batteries with need ones and shot for another 90 minutes without issue. In three years I’ve yet to see find a flash by any brand that can match it. I also considered the F60 but read many negative reviews about over heating. While over heating complaints are usually exaggerated when 99% of reviews on Sony’s forum were reporting over heating after 10 minutes it more than just opinion. Apparently there was a single faulty wire. Hence the F60 is more expensive but the newer less expensive F43m is far better. If you have an older style Minolta flash mount on your Alpha there is an adaptor for only $23. Make sure you buy the Sony brand! I tried two other adaptors which did not work. Link to post Share on other sites More sharing options...
