Camera Crash - Menu Info Disappears
Camera A7rII
Metabones Adaptor MIV
Canon Lenses
Sony Camera Firmware V2
JJC TM Multi-Function Timer Remote
Outdoor temperature 34 degrees
My camera is a little over a month old.  I am a relatively new Sony user.  On my last camera shoot, I was taking photos just fine and then the camera went from working to displaying "Camera Error" and either turn camera off and on again or the word restart.  Can't remember exactly which.  I had to do this twice before the camera started working again.  About 1/2 hour later, my menus and buttons no longer worked.  I would press the function menu, no display; same with the big control wheel to access ISO and the menu button itself no longer worked.   I turned the camera off and waited a few seconds and then back on, which seem to restore the menu and button functions.
About 2 weeks ago, the camera seemed to be "stuck" in Auto ISO mode and I was unable to disable that function and finally had to reset camera settings.
Any clues - should I take the camera back?
Camera A7rII
Canon Lenses
Return it. If you mention the adapter, they won't take it back.
Return it for refund and buy the replacement from a different
supplier. If you were to try returning a second camera with the
same failure to the same supplier, you might encounter resistance.
The adapter could be faulty and is destroying the firmware in the
camera. You need to risk a second camera to find out. Kuhpische ?
EDIT:
Should have mentioned possible alternate method
[circumstance dependant]:
If ... IF ... you bought the adapter AND the camera from a well
respected place like B&H or Adorama, and were sold the pair as
a compatible outfit, they would be extreeeeeemely likely to take
both back for replacement. They do huge volume, and reputation
is as precious as time. Therefor, they know that taking back both
is faster than figgering out which unit is at fault. If the camera
was killed by the adapter, both are now faulty. If the camera had
failed for its own reasons, then they take back a bad camera and
an innocent adapter, but time is money, reputation is money, and
your money is money. Money talks, nobody walks.
Thank you for your response.  I have used this adaptor on
my A7S for over a year with no issues similar to those
described above on the A7RII.  The adaptor has had it
firmware updated to the latest version.  The camera was
purchased from my local camera shop.
That does seem telling, but it is entirely possible that
the firmware in the later model body is more advanced
and so may be more vulnerable to "infection" by some
unauthorized electronically connected device, i.e. the
adapter. IOW, it's still suggested that upon presenting
the camera for return, that you not mention anything
about using a "smart adapter". There's a very thin line
between "smart" and "lobotomy".
If ... big "if" but not unthinkable ... if your adapter really
did lobotomize the camera, it's gonna be embarrassing
to show up at the local shop with the replacement body
similarly brain-fried.
I see you are a noobie. Welcome ! Now, if you have not
recently [coupla years +/-] been reading photo forums,
you might be unaware that it's become more and more
dicey to use third party devices that communicate with
your camera via hardware connection. IOW, wi-fi seems
harmless, but direct connection seems to be becoming
somewhat of a Pandora's Box ... pre-digital-era meaning
of "Pandora" acoarst ! Obviously, there are devices that
really do enable us to expand our photographic abilities,
but caution is more and more advisable as systems grow
more and more sophisticated.
Guest Colin Scott Johnson
This happened to my A7 II.
I never used an adapter.
Do a search for Camera Error.
It was quite common with the A7 II.
It was only 2 months old and this happened maybe a week after a firmware update.
Nothing would fix it except sending it in for repair to Precision Camera in CT.
It took about a week to get it fixed and returned.
Thanks all.  I did as Colin Scott suggested and did a search for Camera Error and he is right -- it does seem to be quite common, though sad for such an expensive body.   My camera store has taken it and sent it off for repairs under the warranty.  I sure hope this works as I do love this camera in all other respects.
