F-- problem in Sony A7sii
I don't have the Commlite but have you checked the firmware version on the adapter? I know with my metabones upgrading firmware can DRASTICALLY change how the adapter performs.
next I would clean the contacts and ensure that they appear to all be correctly aligned. maybe the adapter has a bent or missing pin? I have not seen a commlite so maybe this is not even possible but look it over.
Next I would talk to the dealer you bought it from and try a second adapter to see if the issues are present with a different version.
