I'm in real estate and every shot has bright windows and dim interior corners in the same frame. I don't have time for post-production, so I'm not looking for any software suggestions. I simply want the automatic, in-camera bracketing of a camera with a great HDR mode. I'm not satisfied with the HDR results that my Canon produces. I'm willing to pay more for a good Sony to get as close as possible to real software exposure bracketing. I want a full-frame mirrorless camera.
Questions: Do Sony cameras take 3 images at once in HDR mode? How many seconds does it delay between shots? (My Canon takes 3 fast shots, but is then disabled for 10 full seconds after every HDR shot to stitch together the 3 images. It's brutal.) Does anyone have any examples of a dim interior with sunny windows? Which Sony would be best for this?
Or am I just expecting too much from an in-camera feature? Thanks so much everyone!
The short answer is HDR is only going to do so much. Blown out highlights are blown out highlights. The good news is that Sony underrates their sensors. Most people I know tend to overexpose a stop or so. You can pull an awful lot of detail out of what appears to be blown out highs.
From another post:
As near as I can tell, the last camera (at least FF) that included HDR was the A7 III. The A7R III has it, so do the A9 and A9 II.
While I didn't check them all, the A7R IV, A7 IV, A7R V, A9 III, and A1 do not have in-camera HDR. They do have HLG, a single frame high dynamic setting, but it's only available in HEIF format.
Without knowing which Canon you're using; there's a good chance that a newer camera of almost any brand would surpass it in dynamic range. However, I wouldn't plan on achieving the kind of results you're seeking without putting some effort into processing, unless you put some time into really learning the camera's abilities and limitations.
As mentioned, the features depend on the camera -- and I can't speak to Canon either.  On the a900 &a850, there are several DRO (Dynamic Range Optimization) settings -- None,  Auto, Advanced, and "manual".  (Different from HDR, DRO is an additional way of handling high contrast scenes with processing IN-CAMERA)  This provides an amazing ability to tone-down high contrast scenes -- but, just as with the Canon, the internal processing of the images slows things down.  How much?  It depends on how many images, the quality, and the amount of adjustment.  It can also be combined with bracketing.  You can read about it -- with examples, on line.  Search  for DRO, not HDR.
Edited by XKAES
I wonder if you have seen this YouTube video by Gary Fong which was uploaded 10 years ago with an A7R camera:
There is a time lag after the shots are taken to generate an HDR image but possibly the time lag is shorter with newer cameras?  I didn't like the HDR images that I have seen before that had exaggerated exposure values but this one looks good to my eyes.
    • The a7iv with the laea 5 is pretty hard to beat. It’ll run all your legacy glass as well as the SLTs with more resolution and better light handling. The more expensive stacked sensor bodies work well with some and not so much with others. Continuous autofocus works but isn’t nearly as dramatic. Unless the a7v comes out with even more advanced stuffs and a non stacked sensor for not a lot more money. And of course you can always add e mount glass as you go, but in my opinion it’s rarely worth the price unless you need the tech specifically. Sigma has some nice options and the 200-600 is nice for sports and wildlife. And the small mortgage 400 & 600. 600 Mino is basically manual focus. It will auto but so slow with the heavy glass it’s not worth the strain on the battery and adapter.  The a68 will keep up with the newer crop sensor bodies well enough that I wouldn’t consider those. 7/8ths autofocus speed, just as bad in low light and similar IQ. Same with the a7iii and older full frame. You’ll game a little but not much for the cost. Should we get the rumored 7r vi that can hang with a Hasselblad or Fuji and retain all the bells and whistles though…
    • I still shoot several A-Mount lenses including the 500/8 AF Reflex (a real hoot! A 500 Reflex in AF?!!), the 28-135, the 85/1.4, the 35-105, and the lowly 100-200 (or whatever it was). I use them with the LA-EA5 on my A1 and A7 IV.  Up until a year ago I also had the 70-210 'Beercan', 100-400 APO, 80-200/2.8 APO HS G (yes, the 'G' designation came from Minolta) and probably a couple others I'm forgetting.  Just use caution if you go this route. Not all of Sony's cameras work the same with all of their adapters, and the adapters are different. Anything older than the A1 and A7 IV need the LA-EA4, which defeats the purpose of going mirrorless. Heck, I still have a Minolta Maxxum 7000 and a Minolta Maxxum 5D, their last digital camera. Might've been their last camera.
    • I have been considering going to a mirrorless camera. The reason I went with the a68 is I had all Minolta lenses from my old SLR I had. I don't know of any other camera that would accept these so I may have to bite the bullet and start with all new gear. Any suggestions?
