On my Sony a7rii, the monitor view rolls (vertical hold) when the monitor is depressed flat against the body. When I extend the monitor away from the body, the monitor vert hold is regained and the screen view returns to normal.
While the monitor view scrolls, the viewfinder remains normal (does not scroll).
