SONY A77 vertical grip gives "Non compatible battery message
Hello everybody
I have an A77ii and a coresponding battery grip.
When inserting a batery on position 1 gives the "Non compatible battery message"
When inserting the same  batery on position 2 everything works fine
When inserting both bateries I get again the "Non compatible battery message"
Tried with a combination of 4 Sony batteries results are the same !!!
All batteries work Ok when used in the camera.
Well I repeated all those tests with my other camera a Sony A77 with identical results.
Tried to find an answer in the web with no luck - the closest to an answer was "This is a known problem with Sony grips"!!!!!!
Is there a way to solve the problem ?? Its there an official answer from SONY ???
Thanks to all the will take the time to read my post and the effort to post a reply
George
Edited by gmatj
