Hi all,
recently I've bought an A7IV, coming from a different system. I shoot with an FE 20-70/4 at the moment. Very easy, very light. My use of the camera is a family use, plus landscape ad basketball photography (my daughter plays on a local team). Not professional, passioned only.
I'm experimenting some issues with the AF tracking in basketball photography. Sure for my inexperience. I'll try to explain.
The camera was set as follow: AF-C, face/eye detection on, flexible spot M /tracking, Af sensibility 1 (locked on).
I start focusing and tracking my daughter and everything works fine. As soon as another player appears between my daughter and me, the AF immediately (!) switches to this new player, losing the original subject tracked (my daughter).
I've read that the AF sensibility set to 1 (locked on) is tuned to stick to the subject selected and follow it, ignoring averything else.
Where am I wrong?
I can't understand..
Thanks in advace
    • Some questions to help you formulate the answer to your own question: In what sense do you feel your 70-350 is lacking? What do you hope to gain from this 'upgrade'? What % of your shots are in the 70-200 range? If this % is significant, the 200-600 is not an option unless you carry two cameras or don't mind lens swapping. What % of your shots is at 350mm and potentially could have benefitted from more reach? Do you need high resolution shots or is cropping in post an option to fix your compositions? Would carrying a lens over twice as big and over 3 times as heavy have a negative impact on your photography (think of fun, mobility, physical strain, packing volume)?
    • Im looking to upgrade my Lens for high school football games, I currently have the Sony - E 70-350mm F4.5-6.3 G OSS Telephoto Zoom Lens for E-mount.   I am comparing the Sony e70-350 telephoto zoom lense to Sony 200mm-600mm G OSS.   Help and suggestions please!
