I know its a video oriented camera, but it has the slot for a ttl flash but missing the in camera settings for it, and when you mount a flash on it does say that it does not recognize the accessory.
My question is, it is posible that this option to be software blocked or the fx30 is hardware limited and is not comatible with a flash?
All i found online about it are just simple no's and no real arguments as why cant you use a flash for photograhy. (the fx30 actually beeing pretty good at taking stills)
Thank you.
