Lens hood can't fit on 55/1.8 after putting on a B+W XS-Pro Nano UV Filter
My suggestion is to not use a UV filter on the FE 55 (or any lens)....  First i am a true believer that a UV filter does absolutely nothing to improve I.Q., second the FE 55 has a concave front lens element that is recessed even further by the front of the lens body.  The odds of dropping it with a direct hit on the front element are very slim....  The FE 55 is one of the sharpest lenses available from any manufacturer and I would never use a cheap B&W UV on a sharp prime lens period.  All you will be doing is adding 2 additional reflecting surfaces to cause potential issue with I.Q.   Also if you think a couple of mm thick piece of UV glass is going to protect the lens if you drop it with the camera attached I think you will be very disappointed in the results...  Most likely the threads from the filter will ruin the threads on the FE 55 and make using a real filter like a polarizer or ND impossible to attach properly....  JUST SAY NO TO UV Filters!
For reasons other than Hoya, B/W etc convincing everyone to use UV filters, there is no reason on todays coated lenses. I shoot in some very tough locations... India and China which I visit 2 or 3 times per year. The dust in India is really bad but I take strong blower and cleaners. I have yet to see lens damage. For my video work then yes, I have to use ND filters almost all the time outside but this is a necessity and not for protection.
So, you choose to preach rather than address the question.
But then, you do call yourself a "true believer" so some
preaching expectedly results :-)
Also, you ignore the real world protective value of a UV filter,
which has nothing whatsoever to do with dropping the camera
or the lens.
  • 4 weeks later...
I also find it annoying to not be able to put a polarizer on and then the hood. Obviously I'd have to remove the hood to rotate the filter, but then I'd like to snap it back on and put it away so it is ready for the next shot (with filter on), instead I have to remove the filter and put it away.
Firstly, there's no optical advantage to a "UV" filter, as, unless you have lenses of pure quartz, glass absorbs UV anyway. You need a yellow filter to cut haze.
I never used protective filter until I got the Fuji 56mm f1.2 fir my XT-1 - don't want to take risks with the front element on that beast!
That said, I've never seen any issues caused by a decent multi coated filter either...
    • Hi. tried this one. I have the same problem and read your post. I tried everything until this. it worked.   LuckySn0wMan •4mo ago•Edited 4mo ago   I've just had exactly this issue recently on my Sony A7r2 and successfully resolved it. I bought this camera used, so looks like the previous owner of the camera tweaked it's firmware to unlock additional languages. These tweaks caused this issue after the camera spent significant amount of time without the battery installed. Note that on ny camera the OpenMemories tweak app is not installed, so I used the pmca-gui PC application to change tweak settings of the camera firmware without the OpenMemories in camera app. So my sequence of actions to fix the camera: Install the battery. Connect the camera via micro-usb cable to your windows bases PC. Power on the camera. It should start in mass storage mode. Download the pmca-gui-v0.18-win.exe executable from the official github page: https://github.com/ma1co/Sony-PMCA-RE/releases. On the Camera info tab press the Get camera info button just to test that the app can successfully detect the camera. Go to the Tweaks tab. Press the Start tweaking (updater mode) button. The Updater mode tweaks tab should popup. Camera display will be completely black and the buttom right LED will be on. Select the Unlock protected setting checkbox. Uncheck the Unlock all languages checkbox. Uncheck the Unlock protected setting checkbox. Press the Done button. Once the app applies all changes to the camera firmware, exit from the app and power off the camera. After power on the camera should start working as usual. As additional info: My camera had the following tweak settings during the gray screen problem: Disable video recording limit: not selected Unlock all languages: selected (possible cause of the bug) Enable PAL/NTSC selector & warning: selected Enable USB app installer: not selected Unlock protected settings: selected After my changes that helped to fix the camera power on gray screen: Not selected Not selected Selected Not selected Not selected
