Best (inexpensive) way to trigger an off-camera Sony Flash
I am trying to find the right trigger to mount on a A1 to trigger my HVL-F60RM. Do any of the Godox (or Flashpoint) triggers work? I keep seeing people saying that one or the other will indeed fire a Sony Flash, but the product descriptions make it look like they only trigger Godox strobes. I'm trying to avoid buying the expensive Sony Trigger.
