I just received a new A7R IV from B&H Photo and noticed right away that, when I tilt the camera, I can hear something shifting inside. If I gently shake the camera it is very obvious. Is this normal? Is it the sensor? This does not happen with either of my A7R II cameras.
The noise is only when the camera is OFF. It makes no difference if there is a lens mounted or not. The noise is similar to a clunk that you hear right after turning the camera on, but it's not exactly the same. My A7R II cameras also make a slight noise after you turn them on, I guess it's the same thing, but it's just louder on the A7R IV. I think it must have something to do with the IBIS and the sensor, it almost sounds like it's clicking into place when the camera turns on.
