I just got an A7S III and can't get reliable recording to 120 fps.  I get corrupt frames in the files, both in S&Q mode and in standard mode dropped to 29.97 fps in Adobe Premiere.  I've tried both XAVC-S and XAVC-HS and the behavior is the same.  I'm using the 280 Mbps bit rate for the standard file and 140 Mbps bit rate for the S&Q file.
I have tried two different ProGrade V90 SD cards and the behavior is the same on both: probably 20% of the clips have at least one corrupt frame where part or all of the frame is from a different time in the clip (usually later).  Sony claims that V90 works for all the 120 fps modes except all I (which I'm not using).
Is this a known limitation of V90 cards?  Or is my camera defective?
Thanks,
rgames
Wich cards?
I am using a "Kingston MLPR2/256GB (256GB SDXC React Plus SDR2)" rated as V90 with up to 300 MB/s (read) and 260 MB/s (write) speed.
My test recordings on the Sony A1 at 8K with 400 Mbps and 4K 120p All-I (600 Mbps) were OK so far.
I know, this does not really answer your question and still leaves the cards or the camera in question...
But perhaps others can comment on your cards, when you give more details.
1 hour ago, 3D-Kraft said:
Wich cards?
As I said above, I'm using ProGrade V90 cards.  They're 64 GB with 300 MB/s read and 250 MB/s write.
Does that info provide additional insight into what's going on?  Do some ProGrade cards work and some do not?
Thanks,
rgames
    • Here it is (almost) mid September (2025) and the problem has not reoccurred (i.e. my Sony a7iii Camera is still remembering the date & time when turned-on). A few days recharging the internal 'RTC' (real time clock) battery seems to be adequate.
    • NB: I will NOT be responsible for any broken/unusable teleconverters. Also, I just want to preface this by saying that I am NOT a Sony shooter; I am personally a Canon shooter so there is no way that I can verify this myself.   Sony's restriction of 3rd party glass using teleconverters is pretty well known. I had a friend who uses Sony and shoots wildlife with me, and he was kinda jealous of Canon and Nikon for having affordable supertelephoto prime lenses available via EF to RF or F to Z adapters. Sure, you could always adapt EF or F glass to E mount, but the autofocusing performance is always lacking.   This was until the release of the Sigma 500mm f5.6 for E mount. However, my friend is still hesitant to get the lens due to the inability of having teleconverters. While researching for him for alternative solutions, I stumbled upon a comment on a video on the Chinese video platform Bilibili saying that there is actually a way to have the Sigma 500mm f5.6 with the 1.4x teleconverter. I messaged this commentator (whom I won't disclose) and this is the method that he entailed:   One could open up the Sony teldconverter, rewire the contacts, so that the contacts on the male side connects directly to the female side, bypassing the chip inside the teleconverter completely, and thus the camera body would not know that a teleconverter is mounted with a 3rd party lens, and the autofocus should work. It should be a fairly easy job, only requiring some soldering skills.   Is anyone willing to verify this? I understand that the teleconverter is still quite an expensive piece of kit, so please don't try this if you're not confident with your soldering skills, or you care about the water resistance performance of your teleconverter, etc. Cheers
    • I use the 24-105 on an A7 IV and an A1, and never feel any vibration of any kind when turning the camera on.
