EVF Sony a7 III "lag"
Hi, i've tested sony a7 3 on sport event and i had a problem with evf lag.
Let me explain better: all pics were retards. I think is because the image i see in evf is not reality, but processed and view on a monitor.
Obviously when i used dsrl i didn't have problems, because the viewfinder is directly the reality
do u have same problems? i can solve with a7r3 and high frame rate?
