Background noise
Hi
I'm shooting with sony alpha7s ii (inlove). and a zeiss lens, 85mm batis. I’ve been trying to find the best settings to shoot in a dark room with a lite subject. For a reason I can’t understand- my background has a lot of noise. Does anyone know what I’m doing wrong? The image attached is shoot with
iso-50
shutter speed- 1/160
f/14
Edited by Olaf W.
Title edited
  • Olaf W. changed the title to Background noise
