I recently purchased the Altura flash and trigger set for my Sony A-850 dslr. The problem is that the flash only fires in pre-flash TTL mode, and not in ANY other modes, and the wireless trigger feature will not work at all....does anyone have any idea what the problem could be? ( I purchased the hot-shoe adapter of course) Is my old camera unable to handle the newer technology?
What Altura Flash ?
Are you sure you have the Sony version ?
Which hot shoe adapter ?
The A850 is also using pre-flash TTL so it should work unless there is an element in your set-up that is not communicating properly with the body
Edited by michelb
