Hello everyone !
Ever since i bought the sony 70-200mm f.4 i felt like at shorter zoom ranges (around 70-100) there was a real problem with quality ! Here i joined two pictures cropped at 100%. one with my prime 85mm 1.8 sony lens, the other one with the 70-200 f4 sony lens.
See pictures Pay attention to the cans and bottles in the bin...
Is it normal that i have this "blurry, ghosty, soft" look on all the edges with this telephoto ? What is it called ? What is the cause of it ?
I would love to know if other people noticed this, or if i just got a bad copy all this time ? I feel very disappointed for a lens at this price point.
Thank you :)
