After a long run with DSLRs, hard rock guitar playing and 100+ mile long ride with my bicycle, I have problems with my wrists on both hands. Heavy things are not for me to fool around for long walks. What is the lightest full frame lens that I can get for my A7 II? Are there many options with and without adapters?
The Samyang 35mm f/2.8 is about as small and light as it gets if you want AF. Lens weighs about 80 grams. Don't own the lens but reportedly image quality is pretty decent considering the weight and cost of the lens. Arguably on par with the 35 f/2.8 Sony/Zeiss.
Edited by Pieter
It looks tinny and well priced. I will certainly go for one. That will make it and unbeatable mirrorless bundle. Quite lightweight and very capable nevertheless.
Thank you!
One of the first lens I bought was the Sony FE 35 f2.8. Nice, compact and the reverse lens hood. I still own it and use occasionally if doing "prime only". I find my favorite walkaround is the 16-35 f4, coupled with the 55 Sony/Zeiss (the second lens I purchased) in my pocket/light lens (no camera space) bag.
Edited by tizeye
  • 5 weeks later...
Secound that!
I used to have one and it was practically glued onto my A7 Mark I. I regret selling it, but when I went the APS-C route it didn't make sense to me any more.
As I'm back at FF, I bought the Samyang 24mm which is in the same ballpark and makes for a very nice landscape and city-combo.
    • I do a bit of astro photography and do a lot of research etc. on best settings to use. I have never heard of anyone using ISO bracketing! Typically, higher ISO settings such as 1600, 3200 or 6400 are used and multiple light and dark frames are stacked to reduce noise. If you are worried about noise in dark foreground areas then just use a seperate exposure for them then blend the exposures in post processing. By the way, I also have an A7R5.
