old long minolta etc lenses
Hi Gang, is there a guide somewhere to which of the older minolta lenses and sgma/tamron
lenses as well, i need a long lens for birds mainly around 400mm or more and have seen loads
of cheap long lenses on ebay, some are minolta some sigma etc, question is which will work ok with my A7ii dslr
thanks
