Strange spots when shooting into the sun
I have strange green uniform spots on my photos when the sun is in the picture. I need to know is this expected behaviour? I must admin it would severely restrict the sunset shots I want if it is.
If it is not expected should I send the Lens for repair or Camera?
I have attached a resized picture straight from the camera that illustrates the point. The forum will not allow full size files. I must say I understand that with a 20+mp camera.
Many thanks
Trevor
  • 2 months later...
I have now had a reply from Sony. They tell me that this is called chromatic abberration and is normal on Sony Cameras
Now I always tought that chromatic abberration caused 'fringing' not a uniform array of dots.
I also thought that Sony G Lenses were advertised as being good, showing very little chromatic abberration.
We'll see what they have to say at the photography show.
