Tethered headset as an electronic viewfinder
Howdy , new around here .
I want to see what my lense is seeing . Director viewfinders where you can attach your own lense seem quite pricey .
Is it possible to use a tethered headset with hmdi input to use as an electronic viewfinder for an A7sll ? I would imagine it would be a very helpful way to view your shot rather than a stinkin monitor which you have to guard from the sun .
Thank you !
I would expect some very serious problems regarding your equilibrium and your orientation is space, when wearing a headset which only shows you what the camera is pointing at. Bumping into something would be one of my least concerns, stumbling off of a cliff or being run over by a car while your camera is looking the other way would be quite a different matter.
In other words: I advise against even trying. Think of all those smombies, who keep their eyes glued to their smartphones and running into all kinds of problems, even fatal ones.
