Would a SIGMA 150-500MM 1:5-6.3 APO OPTICAL STABILZER fit a Sony Alpha a68?
Hi
I'm looking to buy a 500mm lense for wildlife photography, so I was wondering if a SIGMA 150-500MM 1:5-6.3 APO OPTICAL STABILZER would fit my a68? There isn't alot of information online on this and trying to find a store with Sony equipment is hard.
Thanks
  • 2 years later...
Hi,
This lens is available for Sony A mount and so it would fit your a68.
As the a68 is cropped sensor all the a mount lenses will fit (Full frame cameras need to watch out as some A mount lenses will    have heavy vignetting where the edge of the lens shows in the photo - however, this is mainly in wide angle lenses, I've yet to find it in a telephoto lens.
Here's a link to a review of the lens from a good camera shop in Britain, who I have found very good for used equipment.
https://www.wexphotovideo.com/blog/reviews/sigma-150-500mm-f5-63-dg-os-hsm-lens-review/
Super-wide, full-frame lenses will only have "heavy vignetting" -- AKA, light fall-off -- if they are not retro-focus lenses.  All of these require a mirror lock-up to use -- such as Minolta's first two 21mm lenses.
Those that have a retro-focus design -- like Minolta's later 21mm and 20mm lenses -- largely avoid light fall-off, and it is typically eliminated by stopping down a couple of f-stops.
    • Thank you XKAES  and Pieter for responding to my query. Since my post, I figured out what I was doing wrong, and now I am getting more predictable results. To answer a few questions, I am using a Sony A7R5, and am aware that it is ISO invariant, however at least for what I've tried, there are limits to how much you can "push" exposure in post. I am doing some night/astrophotography and when I set iso to 400, and increase exposure in post, I get more noise in dark foreground areas than if I use a higher iso in camera when I increase exposure 4 stops or more. I wanted to do iso bracketing so that I could further compare the results and choose the settings that gave me the best results. I had hoped that I could set the minimum iso to 320 and take 3 or more images at 2 stop increments, but I now doubt that's possible. Since the camera is choosing iso based on the light it detects, it may or may not start at 320. Any thoughts or suggestions would be appreciated.
    • Thank you @Cameratose. I have tried Shotcut and it seems I can work with the video. I still don't understand why this works and yet iMovie does not. But happy to have a work around and I will keep learning. Thanks for your help.
    • Out of pure curiosity: why would you want to shoot a bracket using ISO as your means to control exposure? Sony cameras are virtually ISO invariant (save for the second gain step), so raising ISO in camera or in post-production yields nearly identical results. Most people shoot bracketed exposures to gain detail in over- and underexposed areas, but when you use ISO as your exposure variable, you might as well just create the bracket in post by raising/dropping exposure. You don't gain any dynamic range that way.
