City in Motion : Bandung, Indonesia
haykalyuqdha
Some nice shots inside, but frankly: this looks like you tried to cram as many different effects into this as at any rate possible. I somehow miss a story line, too.
Thank you for comment. Ah yeah, you are right because at first this video was for Instagram purposes. So, I only have 1 minutes to sum all the stories and maybe that's why there is a miss in strory line too. Thank you again for noticing that. I really appreciate your comment there
