a6500 - how to return to 'movable' expand flexible spot?
Hi all!
Question: Sony A6500 --> FN button --> Focus area --> Expand Flexible Spot
When I select this I can change the position of the focus with the control whee (up, down, left, right). When I click the round button in the middle of the control wheel, the spot is fixed and can no longer be moved with the control wheel. How can I get back to moving the spot.
Currently I go back into the: FN menu and confirm 'Focus area' and then confirm 'Expand Flexible Spot'
Is there a shorter way to achieve this?
Many thanks!
