Mylène, portrait and bokeh (Minolta 100/2 on Alpha 7)
fute77
Hi all,
Here is a result from a photo session made in june
I am really in love with the good old minolta 100/2. I have compared it with the CZ 85/1.4 (a mount) and it stand the comparision
let me know what you think
loneliness by Fabrice, sur Flickr
Sony Alpha 7 with LA-EA3 and Minolta 100/2
ISO 125 f/3.5 1/320s
Nope.
Need to stop down, and open up ...
your iris and your eyes, respectively.
Subject is very well photographed.
Thaz really without question, light,
expression, etc, all really well done.
The "stop down ... open up" thing is
about the reeeeally unfortunate item
rising up out of her spine or shoulder.
I see that as a result of a trusting in
rather wide apertures to relieve the
photographer from needing to keep
an eye on backgrounds. IMNSHO,
the distracting background object is
something SO obvious that anyone
who was even partially watching for
background problems could not fail
to catch it. But the belief that a wide
f/stop will allow one to concentrate
only on the subject is misleading. It
did result in a really great rendition
of the subject ... thaz way cool ! But
it seriously marred the total image
by allowing that uncool background
thing to intrude as much as it does.
It's a drag, cuz so much else is just
so verrrry beautifully done :-(
At the risk of sounding crazy, let me suggest a camera
feature. It will never be produced, but one can learn to
do this with one's mind, instead of relying on a device.
OK, here's the design concept for the feature. It's NOT
for SLRs, only for live view cameras. One key ability of
live view cameras is presenting a full brightness image
for viewing, even if viewing thru a smallish f/stop. The
purpose is to warn of distracting backgrounds.
The idea is to sequence the iris and shutter as follows.
In this example, the f/stop intended for good exposure
is f/2.8. So here's the sequence:
1. Viewing/composing at stopped down to  f/5.6 or f/8.
2. AF activation or MF-aid causes opening to fully open.
3. Cessation of focus action drops iris back to f/5.6 or 8.
4. Instant before shutter opens, iris opens to f/2.8 [the
f/stop intended for good exposure].
The essence here is to bring background objects into
more noticeable focus, even tho they will be somewhat
softened at the actual f/stop for the exposure. Reason
for this is that, even tho soft-focused, many background
objects should not be ignored. Problem is that objects
look more distracting in a finished photograph than they
seem while composing and timing the original exposure.
I repeat that describing the feature is a conceptual way
of explaining the need to practice a visual skill. It's not
that I imagine the feature ever being implemented.
