I agree about sensor revolution. They did not mention, that new on-sensor PD-AF can drive existing a-mount lenses now, without using old SLT adapter. This is greatest news for people who invested heavily into a-lenses.
    • Some questions to help you formulate the answer to your own question: In what sense do you feel your 70-350 is lacking? What do you hope to gain from this 'upgrade'? What % of your shots are in the 70-200 range? If this % is significant, the 200-600 is not an option unless you carry two cameras or don't mind lens swapping. What % of your shots is at 350mm and potentially could have benefitted from more reach? Do you need high resolution shots or is cropping in post an option to fix your compositions? Would carrying a lens over twice as big and over 3 times as heavy have a negative impact on your photography (think of fun, mobility, physical strain, packing volume)?
    • Im looking to upgrade my Lens for high school football games, I currently have the Sony - E 70-350mm F4.5-6.3 G OSS Telephoto Zoom Lens for E-mount.   I am comparing the Sony e70-350 telephoto zoom lense to Sony 200mm-600mm G OSS.   Help and suggestions please!
