I'm a recent convert from Nikon. I have an A6300 and A7M3. I'm starting to purchase a collection of lens for both. I don't have a macro lens yet. So, I was experimenting with the 55-210 mm E mount lens  on the A6300. The file attached was untouched. Only reduced in size for the web.
(Sony A6300, 55-210 mm DX at 210 mm, f/6.3, 1/800 sec, ISO 400)
John
Edited by DrJohn
  • 4 weeks later...
Very interesting issue for me. I have an a6000 with the 24 1.8 lens. That lens should just do for landscapes but it allows me to focus very close and between it's exceptional sharpness and the 24mp of the camera I can crop to produce very sharp  macros.
Edited by Dondeando
