hi i have live view setting in the menu checked off and while i was on a plane recently i took the cam out and aimed it thru the moving props and to my surprise the viewfinder showed me the prop slowed down so it looked still,i had shutter at around 1/3000. i was amazed at that feature,i just took the cam down to a local spot where theres a provincial flag blowing in the wind,i can't seem to recreate that freezing of the moment even with shutter speed very high again,the live view setting is still on,is there another setting that i may have on or off that affects this feature,thanx in advance
    • Some questions to help you formulate the answer to your own question: In what sense do you feel your 70-350 is lacking? What do you hope to gain from this 'upgrade'? What % of your shots are in the 70-200 range? If this % is significant, the 200-600 is not an option unless you carry two cameras or don't mind lens swapping. What % of your shots is at 350mm and potentially could have benefitted from more reach? Do you need high resolution shots or is cropping in post an option to fix your compositions? Would carrying a lens over twice as big and over 3 times as heavy have a negative impact on your photography (think of fun, mobility, physical strain, packing volume)?
    • Im looking to upgrade my Lens for high school football games, I currently have the Sony - E 70-350mm F4.5-6.3 G OSS Telephoto Zoom Lens for E-mount.   I am comparing the Sony e70-350 telephoto zoom lense to Sony 200mm-600mm G OSS.   Help and suggestions please!
