A7RM3 focus settings for birds in flight
Hi Jim,
I do have MR2 set up for "wildlife", or moving targets. Since I'm using the Sony FE 100-400 lens the switch to manual is easy, and fairly quick. It is a mechanical button on the lens itself, and does not require any menu access. Hence the tendency to switch to manual when auto focus has difficulty. Since I always shoot "wide open", this is the only change I make for birds, so only one MR location. I have the other two set for "Landscape" and 'Portrait", although these are just "starting points", since I commonly end up shooting manual mode (night shots in particular).
  • 1 year later...
