A7R3 and phottix TR-90
Hello
I used to have a phottix TR-90 remote and intervalometer with my A7II and it worked perfectly fine. I loved the on off button on the remote and the timer that starts automatically each time à used the remote.
But for an unknown reason it is not working properly on my A7R3. The intervalometer works but not the remote. :huh:
Does anyone have the same issue ?
Else what remote could i buy to have the same functionalities ? (even a wireless remote)
Thanks.
