I'm baffled by something which should be simple. At the bottom of the Sony A9 viewfinder-- Left to right:
shutter speed---- aperture----exposure meter from -5----0----5+      and  ISO
I don't understand the exposure meter and how it is used. It is highlighted from   -2 to +2    but is grayed out -5 to-3 and +3 to +5
If I am in Manual mode and alter the variables for exposure the cursor seems active from -2 to +2 but then drops off the screen above and below that (the grayed out parts of the meter). What gives? I can't find an answer in the manual or in Friedman's Sony A9 Guide book.
Any help would be most appreciated.
Pozos
Thank you, Chrissie. This is helpful but does not entirely answer my question. If I am in manual mode and looking thru the viewfinder and at the correct exposure the cursor is over the "0" in the exposure meter. then if I point the camera to a new view with different light source the cursor will move up or down the meter scale as expected depending on the new lighting---- but it only moves up or down within the range of -2 to +2 and then falls off the scale. Perhaps this is the design but it would make sense for the cursor to continue to move up or down the entire scale. I am wondering if there is a setting that I am missing?
Pozos
I have not got your exact model, but general
Sony experience hints to me that the grayed
out range is will prolly come alive when the
scale represents the amount of AE biasing
dialed in when using the AE modes.
Sony simply tends, across the model line, to
use only a +/- 2EV M-mode scale, all else
being just "high" or "low". IOW you have not
overlooked any info/readout settings.
OTOH you may have overlooked possible
workarounds. Depending on the reason you
might desire a longer scale, you might find
that an AE mode more versatile/controllable
than M-mode if you set your AEL to "toggle",
which creates a sort of hybrid manual-auto
mode that responds to the AE biasing dial.
Bullet point #4 under NOTE seems to explain this behavior for me...
  • Only a value between -3.0 EV and +3.0 EV with the equivalent image brightness appears on the screen when shooting. If you set an exposure compensation value outside this range, the image brightness on the screen will not be affected, but the value will be reflected in the recorded image.
for me...
  • equivalent image brightness appears on the screen
  • when shooting. If you set an exposure compensation
  • value outside this range, the image brightness on the
  • screen will not be affected, but the value will be
  • reflected in the recorded image.
Readouts of only +/- 3EV is a limitation of the monitor but
not of the EVF. Look very carefully at the page you linked.
The EVF has the +/- 5EV scale that the OP seeks to utilize.
Thaz why using AE modes with AEL set to "Toggle" is the
workaround ... if readouts outside +/- 2EV is a major issue
for the user. Otherwise, it's simpler to go with M-mode and
tolerate the limited metering scale.
  • 1 year later...
    • I have my A7C set to back button focus (using AF-ON button) and half press disabled. I am using "Tracking Expand Flexible Spot" focus area which I like for street. The problem I am having is after, the square focus block has tracked the subject, which can sometimes be to the edge of the frame and if I release the back button it stays there and from then on I can't move the square back to the centre. Any attempt to use left, right, up, down on the joystick just takes me into the function for the joystick. Occassionally it plays ball and moves for me, but I can't fathom out why, but 80% of the time it stays where I don't want it to be. I am assuming I am doing something wrong, but don't know what. Is there any way (in order of preference) to: Make the joystick control the focus square when I want it to? Make the focus square default to the centre of the screen? Disable the functions on the joystick so it only controls the focus square? Any help much appreciated
