June 1, 201510 yr Hello all, I recently purchased the Sony A6000. So far, very nice camera, loving everything about it except for the relatively mediocre battery life. I am a little confused about the operation of the camera with legacy lenses, but I'd like to learn more. What I would like to do is be able to use one of Nikon's older AIS lenses, like the 55mm f/2.8 AIS Macro: http://www.amazon.com/Nikon-55mm-Micro-Nikkor-Lens/dp/B0000BVDZZ I understand that I will need an adaptor and that not all adaptors will electronically communicate. So, if I get the Metabones F-Mount Nikon adaptor, for example, will I be able to meter in aperture-priority mode, or will this be full manual? Will the camera at least be able to meter? Lastly, will I be adjusting the aperture via the on-lens aperture ring and the shutter speed via the camera itself? This adaptor: http://www.bhphotovideo.com/c/product/983738-REG/metabones_mb_nf_e_bm2_nikon_f_to_e_mount_nex.html/prm/alsVwDtl Or even the Vello, which is cheaper: http://www.bhphotovideo.com/c/product/839149-REG/vello_la_nex_nf_lens_mount_adapter.html/prm/alsVwDtl Thanks guys. - Steve
Advertisement Hi sdnet01, You may be interested in this: Using Nikon AIS lenses with the A6000 . I'm sure you'll find what you were looking for!
June 1, 201510 yr Everything you can do with a pin hole you can do with a non-coupled adapted lens. The advantages of such a lens over a pin hole are that it's much sharper, and that the size of the "pin hole" is adjustable. The disadvantage of a lens over a pinhole is that with a lens, you gotta focus it [duh] ! You can easily experiment with the way your camera will behave with an adapted non-coupled lens. Make a pin hole and tape it over the body flange. Since you don't need really sharp images for such an experiment, use a really BIG pin hole, like not pin-size but 10-penny-nail sized or even pencil sized. The bigger hole will provide a brighter image, more nearly like an actual lens. Don't worry that all your subjects look "ghostly". Not joking. You imagery will be vague but somewhat recognizable and you can mess around with the controls to watch what happens. You'll discover how the difference between viewing modes will affect things, and you can watch the "A" mode at work [it works normally]. With no special cleverness at all you could even make the pencil-hole adjustable in size to get a better experience of the "A" mode. You can play with the meter in any mode. You can even use the "S" mode. It's not automatic exposure but it has a somewhat different behavior than the "M" mode. Feel free to incorporate some clear plastic or such in the "pin-hole" just to seal the body chamber against dust. When the camera is on, the sensor has a mild static charge that can attract any dust that wanders in. After experimenting, if you're satisfied with what controls and features you'll be enjoying, adapt a lens and enjoy those sharper brighter images ! PS: Your pin hole FL is about 1 inch, so a 1/8" hole is about f/8, 1/4" is f/4, etc. `
June 2, 201510 yr Author Thanks Golem, understood on the pin hole concept. I was talking about the specific capabilities of these adaptors, though. For example, I've heard that with some adaptors, you're always stuck at essentially the widest point of the lens. Here's a source that discusses this: http://www.bhphotovideo.com/explora/photography/hands-reviews/overview-lens-adapters Of course, I want more exposure control over my photography, so I want to make sure that I understand what I'm getting. Thanks.
June 2, 201510 yr The adapters work fine, you can either adjust aperture on the adapter or on the lens itself with nik ais glass but not in camera only shutter speed, im using 28 3.5 & 50 1.8 ai and both are great sharp bright good colour i shoot full manual but can shoot shutter priority not aperture priority or auto [hang on, or is it the other way around lol?] cos aperture can only be adjusted on the lens of course. I like the nikon glass so much im buying an 85 1.4 tomorrow for 400$ for portrait, i use metabones adapter costs more but better made engineered and tolerances are tighter the cheap ebays one was ok but not quite as sharp, if you want to see results look at my gallery some shots are with 28 3.5. The old nikon glass is some of the best in my op. I even used a nik 70-210 m/f macro zoom for a while, thats the pidgeon shot in my gallery, the rendering is superb. p.s. You dont get all the exif data with these lenses nor any electronic contact, but doesnt matter to me. And zoom/close focus window with peaking too works brilliantly. edit, sorry i should add, the camera meters in body through the lens[so i believe], so it will work fine
June 2, 201510 yr Author The adapters work fine, you can either adjust aperture on the adapter or on the lens itself with nik ais glass but not in camera only shutter speed, im using 28 3.5 & 50 1.8 ai and both are great sharp bright good colour i shoot full manual but can shoot shutter priority not aperture priority [hang on, or is it the other way around lol?] cos aperture can only be adjusted on the lens of course. Thanks, appreciate the feedback. What I ended up doing was buying the 55mm macro AIS lens along with the Fotga Nikon F-Mount "hollow" adaptor. This is basically just a mount junction between the lens and the camera, no glass, no nothing. http://www.amazon.com/gp/product/B009GFXIAE Since it was so cheap, I'm going to test this out and, if need-be, look for other options in the future. But for manual focus AIS lenses where I'd need to manually meter anyway, I can't imagine that I would need anything more than this.
June 2, 201510 yr You will be fine, there a great fit for the sonys, nice and fairly compact, beautiful focus mechanism, beautiful glass. That adapter will do the job no probs. I used a 16$ ebay one and it worked fine. Manual shooting is just the best. Theres a distinct pleasure nailing a shot that way i say. That 55 is a great lens too. Sorry i over explained a bit in first post lol. Im not sure with a6000 but may be able to do auto iso+ auto shutter too with the nik glass, can on my a7m2? Cos your using apsc, it will be longer mm and sharper too using only centre part of lens.
June 3, 201510 yr Steve, I have a non-AI 55mm f/3.5 Nikkor Macro lens that I use with a Fotasy adapter. The adapter is similar to the one you got from Fotga. All it does is spaces the lens out from the sensor to the correct distance. Once you enable "shutter release without lens" in the menu --you are good to go. This allows the camera to capture an image with no lens attached (which is what it thinks it is doing since it only is a dummy adapter). The adapters that have aperture control are for the AF lenses that do not have an aperture ring on the lens (like canon EF lenses) and are expecting aperture control via the camera body. If you would use a dummy adapter with one of these lenses you would be forced to shoot wide open. As mentioned metering is TTL. You control aperture and focus, obviously, via the lens. I shoot my adapted lenses often in Aperture priority. The camera then sets shutter speed. In this mode, ISO can either be set manually or automatically via Auto-ISO. In more controlled shooting environments I shoot in Manual...but Auto-ISO is not available in this mode. Cheers and HTH,
