Shot using my monochrome converted a7R-II(m). Shot on the Washington coat in Ilwaco. Sony a7R-II(m) monochrome converted, Nikon 28mm 1:1.4 @ ƒ5.6, 1/800, ISO 640. You can see more here: www.monochromeimaging.com
This camera has been a real pleasure to use; reminds me of the film days, but without all of the mess. This is the only converted a7R-II in existence at this time.
