Hi !
I got a Sonya6000, recently i took videos. But after putting them on my laptop (macbook pro retina), the rendering wasn't good... The videos wasn't smooth and when i did pause I could see double images...
Lets see the picture in attachment
Thanks a lot for your help !
Lucas
Hi Lucas,
What you are seeing is the combined images of the odd & even fields of an interlaced video frame (eg 1080-50i (PAL), 1080-60i (NTSC)) when you try to look at it as a still frame.
Always much more noticeable on fast-moving images.
If you want to pull stills from a video clip then you should shoot in a Progressive frame mode (eg 1080-25p (PAL), 1080-30p (NTSC), otherwise you will have to de-interlace your footage first.
It's all pretty well explained here:
https://www.videomaker.com/courses/699/how-to-deinterlace-footage
;D
Hi Lucas,
Hi Lucas,
;D
;D
Yeah thanks a lot ! :) :)
    • hello and please forgive me if I posted in the wrong place  literally this is what happened ; yesterday I shot a few frames with my beloved Super Tak 50mm 8 elements , all fine & dandy  about four hours ago I mounted the autofocus for M mount , the first version from Tech-Art ( or Art-Tech ? )  slapped on a Leica 90mm f4 and to my utter disbelief , being set on A priority , single shot auto ISO , as it was for a very long time , each and every time I pressed the shutter button it rattled six (?) frames , and the LCD informed me that < processing >  the result was one frame , but I couldn't tell if it is HDR or not , being set on JPEG accidentally  and yes , I did read TFM , but , alas , to no avail  for years I used on my two Sony cameras only manual lenses , 'coz I've got only two autofocus ,  please help !   some time ago I solved the eternal problem with batteries ; I nicked my daughter's "bank" shoved in camera a dummy battery , and needs recharging once in two months , moderate use  got a wide(ish) neoprene strap , ziplocked twice the bank & Bob's your uncle maybe someone will find this one useful    impossible to count , thanks
    • I didn't properly stop a video before pulling out the card, after recording 13GB of video. I'm trying to recover the RSV file that was saved to my CFExpress card. I know that there are services that charge $50-$75 to recover the file, but is there a free service that I can use? Thanks in advance.
    • Well I totally agree with your point, but apparently OP found the 18-110 to be manageable for this use case 😅
