My recently acquired Phottix OdinII TTL for Sony MIS, works just fine with my A7RII, not my A7s.
I have the Phottix Indra 360, it just does not get triggered by the A7s at all.
I use both Sony and Canon L lenses with a metabones adapter on both/either cameras.
The lenses don't seem to make a difference. Tried both combinations.
I have a Sony flash which works on both cameras. everything else works fine on both cameras, no issues.
Any ideas? suggestions?
