HI Everyone
Feeling really stupid right about now.  My daughter purchased a Sony a6000 camera yesterday.  i went today to purchase a memory card for her (picked up a Lexar Pro 64GB SDXC 150MB/s) and we keep getting an error message that the card is not compatible. I tried inserting a few of my cards Sandisk and Promaster, all of which "Class 10"
What are we doing wrong?
Thanks
Hey! interesting to hear this as I also have issues with this setup.
I also have an a6000 and recently picked up the Lexar Prof 1000x 64gb card.
Where exactly do you get the messages about incompatibility?
I do not get the messages, but pretty often the camera just refuses to read/write from the card (at least it seams so), the red lamp write indicator remains on for ages. Turning on/off helps but after all it is very unreliable for me to use the card.
HI Everyone
Thanks
If the Sandisk card is working then I would return the Lexar Pro and pick up a new sandisk instead. Someone else on the board had issues with a Lexar card as well, maybe there is a quality control problem.
There's no reason to use these ultra speed cards.
The camera does not write anywhere near that fast.
Learn to read the packaging. The big numbers on
the front of the package is the "read speed" aka
"transfer speed". In the [extra-] fine print on the
reverse side of the package, look for the "write
speed". It's not always given, but when it is shown,
it's anywhere from 25% to 60% of the "read speed".
Various cameras write at speeds from about 25 to
65 MPS. Most users do NOT benefit from SDXC over
SDHS cards. Acoarst nobody HERE wants to believe
that they're just one more of "most users". And most
[maybe more than "all"] sales associates will tell you
that a faster speed on the front side of the package
means your camera will run faster. I heard it again
merely hours ago ! But I did not, and will not, correct
them. Thaz just pissin into the wind.
@Golem: So how exactly is this helping with our problem?
I took this card because it wasn't significantly more expensive and I don't wanna get in to trouble at any point because I wanted to save $5 when buying a memory card. I'm computer scientist who likes hardware, I know the numbers.
You're right with what you are saying, it just doesnt fit into this thread because I do not see how this makes my card more reliable.
There apparently IS a congenital problem:
https://community.sony.com/t5/Alpha-SLT-DSLR-Cameras/Formatting-64-gb-sdxc-class-10-in-a6000-fails-and-goes-back-to/td-p/351590#
My particular a6000 formats cards with no problems.
But I use 32gig SanDisk SDHC cards not of any great
remarkable speed ratings.
I use several different cameras which, statistically,
ought to set me up for a failure in at least one of them.
None of them has ever seen a firmware update.
I do use a 64gig card in an A7M2, but all the others
use 16 and 32gig SDHC cards.
    • Thank you XKAES  and Pieter for responding to my query. Since my post, I figured out what I was doing wrong, and now I am getting more predictable results. To answer a few questions, I am using a Sony A7R5, and am aware that it is ISO invariant, however at least for what I've tried, there are limits to how much you can "push" exposure in post. I am doing some night/astrophotography and when I set iso to 400, and increase exposure in post, I get more noise in dark foreground areas than if I use a higher iso in camera when I increase exposure 4 stops or more. I wanted to do iso bracketing so that I could further compare the results and choose the settings that gave me the best results. I had hoped that I could set the minimum iso to 320 and take 3 or more images at 2 stop increments, but I now doubt that's possible. Since the camera is choosing iso based on the light it detects, it may or may not start at 320. Any thoughts or suggestions would be appreciated.
    • Thank you @Cameratose. I have tried Shotcut and it seems I can work with the video. I still don't understand why this works and yet iMovie does not. But happy to have a work around and I will keep learning. Thanks for your help.
    • Out of pure curiosity: why would you want to shoot a bracket using ISO as your means to control exposure? Sony cameras are virtually ISO invariant (save for the second gain step), so raising ISO in camera or in post-production yields nearly identical results. Most people shoot bracketed exposures to gain detail in over- and underexposed areas, but when you use ISO as your exposure variable, you might as well just create the bracket in post by raising/dropping exposure. You don't gain any dynamic range that way.
