Golem Posted October 30, 2015 Share Posted October 30, 2015 I was shooting at the wall, checking miscelaneous lens hoods as to their fit on various lenses, as to vignetting, etc ..... so I was shooting the same image over and over. But the resulting exposures appeared to be varied over a range of about 0 to 1+ EV, like some kinda erratic bracketing. Then I noticed that some were brighter in their upper half, or lower half, or shadowed along one of the long-side edges, which would mean problems with the timing between first and second curtains of the shutter. So I slowed the shutter way down to speeds where such timing is almost irrelevent and my fears were confirmed. Those exposures did not exhibit the problems seen in the higher speeds. Anywho, I had recently fitted that room with LED lighting, which I didn't realized has even worse pulsing effects than compact fluorescents. All the lens shade testing occured at night. Next day when it occured to me to possibly blame the LED lights, I ran shutter speeds tests by daylight. No problem to be seen. I retested in the LED-lit room and the problem was still there. It's definitely the LED lighting causing the problem. ` Link to post Share on other sites More sharing options...
Advertisement Posted October 30, 2015 Posted October 30, 2015 Hi Golem, Take a look here Household LED Lighting Mimics Shutter Failure. I'm sure you'll find what you were looking for!
Al Pha Posted October 31, 2015 Share Posted October 31, 2015 Same experience here. I regularly shoot in a Hare Krishna temple that has LED lights on the altar and in the main room. Shots taken at the same settings (aperture, shutter speed, ISO) look very different because of the LED lights. Link to post Share on other sites More sharing options...
Golem Posted November 1, 2015 Author Share Posted November 1, 2015 As this type of general purpose lighting proliferates, an old quandary is somewhat transmogrified. For those of us typically shooting at marginal handheld speeds indoors, I had puzzled over whether IBIS was the answer [for obvious reasons] or was it rather more of a benefit to go for improved High ISO quality, to allow raising the shutter speed. The latter option would not only reduce the effect of a less than steady hand holding the camera, but also help with reducing blur from subject motion. Acoarst, such a quandary has two differing solutions depending upon the degree of subject motion ... if any at all. And now ... AND NOW ... we have strobing LED lighting that may mean avoiding speeds over 1/60, or possible even avoiding speeds over 1/25. There's a minor thing about whether you have 50 or 60 cycle AC mains current. A more significant factor is the max synch speed of your shutter. Synch speed is the highest speed at which the mechanical shutter uncovers the entire sensor. However at max synch speed, that full uncovering does not dwell over the sensor but for a brief moment, yet the entire travel time of the shutter is much more than that brief moment, so the LED could be dark at that very moment. IOW it's like an improperly synched strobe shot. =================================================== Kinda Techy Stuff: As speeds slow further below max synch speed, the full open "moment" get longer. The "wrong moments", those that yield streaks, bars, shadows, and generally darker exposures do NOT get longer, so they'll proportionally contribute less to the overall time of exposure. Most shutters today are a traveling "window" moving across the sensor. The SPEED of travel never changes, but the "window" can vary from a narrow slit, crosswise to the direction of travel, to a rather large long rectangle whose long side parallels the direction of travel. The longer the rectangle, the more the LED pulsing is able to complete its cycles during FULL uncovering period [uncovering the sensor]. But the longer the rectangle the SLOWER the actual shutter speed. Obviously, in the "traveling slit" mode [faster shutter speeds] the light source must be absolutely steady as the slit traverses the full size the sensor. IOW, it's a reeeeeally fast, very small, mechanical scanner. You wouldn't want the lamp in your flatbed scanner pulsing during its travel across the image, right ? ==================================================== For the Geekishly Curious Only: The actual "windows" do not exist physically. If they were physical, they could be larger than the space in the camera where the shutter lives. The windows exist in time, not in space .... sort of. Yes and no. They existed on a roll of cloth [with rectangular windows in it] many decades ago, when cameras were larger. Today, the slit-sized opennings are physically there, but the rectangular opennings longer than the dimensions of the sensor are compressed, mechanically, not digitally. If you know that there are 1st and 2nd curtains in the shutter [remember "Electronic First Curtain"? well, for the moment, forget it]. To understand the mechanical compression idea, you have to realize that "1st and 2nd curtains" is archaic jargon, far more acurately stated as "Leading and trailing blades". The travel speed of the blades never changes, but the shutter timing circuit determines how much lead time [head start] to allow the leading blade before the second blade is allow to go chase after it. That delay time determines the effective shape of the slit or rectangular "window". A rather long delay time effects a rectangular "window" that is longer [can be MUCH longer] than the physical size of the sensor and the physical space allowed for the shutter mechanism. ` Link to post Share on other sites More sharing options...
pilsburypie Posted November 3, 2015 Share Posted November 3, 2015 Just trying to get my head round this from a video perspective. Sure on a still photo, you might get the "wrong moment" of the frequency of the LED light, but how noticeable would this appear on video shot with the same shutter speed? Video in its simplest term is a flick book of still images. I suppose it depends on how often it takes a "duff" frame.... Link to post Share on other sites More sharing options...
Golem Posted November 3, 2015 Author Share Posted November 3, 2015 Just trying to get my head round this from a video perspective. Sure on a still photo, you might get the "wrong moment" of the frequency of the LED light, but how noticeable would this appear on video shot with the same shutter speed? Video in its simplest term is a flick book of still images. I suppose it depends on how often it takes a "duff" frame.... Hard to wrap my head around the idea that you've never observed that result. It's a sort of rolling, cyclic, and continuing "passing shadow" effect. There was even a rather similar problem in analog [pre-digital] video. And that was before LED lighting. "Legacy" fluorescents would provoke it ... so it tended to affect mostly "Spot News" and some documentary footage. As to seeing the effect of LED lighting in digital video, at the traditional cinematic shutter speed of about 1/25 [+/-] the effect would be minimized but still be present. Current technology is already pushing video shutter speeds to 3-digit speeds, which increases the problem. ` Link to post Share on other sites More sharing options...
pilsburypie Posted November 4, 2015 Share Posted November 4, 2015 I'm behind the times and only just got LEDs in my kitchen. Not taken any video in there and can't remember seeing it elsewhere. Why does this happen in rooms with LED lighting and not with LED video lights that now seem the norm? Is it due to mains lights in your home working off AC but video light LEDs having a DC converter in them thus removing frequency? Link to post Share on other sites More sharing options...
Golem Posted September 16, 2016 Author Share Posted September 16, 2016 I'm behind the times and only just got LEDs in my kitchen. Not taken any video in there and can't remember seeing it elsewhere. Why does this happen in rooms with LED lighting and not with LED video lights that now seem the norm? Is it due to mains lights in your home working off AC but video light LEDs having a DC converter in them thus removing frequency? Yes .... sortalike that. Dedicated LED video lights run on clean pure DC. Household LED lamps run on a cheap built-in AC to DC converter that has 60 "dead instants" per second in its DC delivery. IOW it pulses at 60hz, unless it's 50hz .... depends upon where you live. Link to post Share on other sites More sharing options...
JCC Posted September 17, 2016 Share Posted September 17, 2016 Most of my shooting is in performance venues. Increasingly they have gone to LED stage lighting. Not only is there the color banding you mention, but RGB white is very peaky, and not true white. The shadows can be very unflattering. JCC Link to post Share on other sites More sharing options...
