Hi, greetings to all
Here are some projects done with do it your self modifiers such as Soft box from an old paper box, strip-light made from pvc glutter, light tent made from pvd pipes + plastic fabric cloth, Beauty dish made from a mid-size bowl.
I hope you guys enjoy these
1. The sun glasses.... [mong-blong]
DIY light tent. 2 speedlight triggered by wireless radio transmitter. 1 from left above @ 1/4 power (gn 54), 1 from right above at 1/4 power (GN 40). To gain detail on inner side of glasses, a sheet of reflecting material placed underneath the glasses
A57 + Sigma 17-70mm f/2.8-4.5
f/25, iso 200, 1/100s
2. Hard-drive
DIY light tent. 2 speedlight triggered by wireless radio transmitter. 1 from left  @ 1/4 power (gn 54), 1 from right at 1/4 power (GN 40).
f/10, 1/125s, iso 100
HD -2
DIY light tent. 2 speedlight triggered by wireless radio transmitter. 1 from left  @ 1/4 power (gn 54), 1 from right at 1/4 power (GN 40). Applying red and blue color-gel
f/10, iso 100, 1/125s
Old  radio
f/16, iso 200, 1/100s
  • 2 months later...
thank you for the attention
I
Your photos are great, really nice control of the shadows. Do you have any "behind the scenes" photos of your setup.
barely I'm sorry that I do not have the photos of behind the scene. However you can follow these links to see the light-setup diagram:
https://www.flickr.com/photos/arif_hidayat/16359779766/- the old radio
https://www.flickr.com/photos/arif_hidayat/16199848257/- HD 2
https://www.flickr.com/photos/arif_hidayat/16198347550/-HD 1
