Im taking my Sony A7iii on a motorcycle long distances on washboard dirt roads.   can this harm the free floating IBIS on my camera?   Im of course packing the camera in soft material to minimize shake and vibration, but there is still some.    What's the best way to keep the camera IBIS safe?
thanks
