I purchased a new FE 70-200mm F4 Macro G OSS II and noticed some very slight side-to-side play at the front barrel. When fully zoomed to 200mm using a macro rail bolted to the lens collar foot as a reference point I measure about 0.025 inches ( 0.6mm) with my calipers. Even fully retracted there is some play, at most half that amount. I think this is probably typical for the lens but I would appreciate hearing from other owners of the lens before I decide to keep this copy. Note that you have to look very carefully to see this movement; it is somewhat easier to see with the lens at 70mm where the front and rear barrels are adjacent.
The lens otherwise seems OK. The local photography organization can do some reasonable Modulation Transfer Function (MFT) and chromatic aberration testing using the free MFT Mapper utility. The MFT is better than my Canon 24-70mm f2.8L II and some older zooms. Not surprisingly it is not as good as a good prime such as a Canon EF 200mm f2.8L or my Canon 100mm f2.8L Macro IS that I have tested.
It also seems satisfactory on the various easy to do tests in Lensrentals How to Test a Lens.
Thanks in advance for your responses.
    • Yes if I do not get any concrete answers here that confirm either way I will have to resort to that.
    • You do know that Amazon offers generous free return service?  Just order any intervalometer that states compatibility with your camera model, try it out and if it doesn't work send it back and try a different brand.
    • Cengizt, what you want to get (and if you are usually mostly happy with the photos you directly shoot in jpg), might be better accomplished if you simply develop your raw files with Sony’s developing program: Imaging Edge Desktop (the one Sony allows to download from their website for free and can be used for the images taken with Sony cameras). Not bad and though very limited, it will allow you at least to recover shadows, a bit less of the highlights (not the burnt ones), correct white balance, and it will automatically correct lens distortions of most Sony lenses (not the ones from lenses of other brands in case you have any). With it, you can set the parameters for the take as you could have done it on camera (for example you can set the image to Vivid, as you asked for) or change the parameters as if you have done it on camera, but afterwards. As it has already been said, every other program does its own interpretation of the raw data of the image the better and more accurately they can. But Sony knows and uses (I might guess) their own developing algorithms (or whatever they are called), so you might be better off in respect to your goal just using the Sony program. After developing the file, you can export as tiff for further editing (and therefore keep on working with a 16 bit per channel image instead of an 8 bit per channel image as a jpg is).   But if you really want freedom and total versatility, using another good specific raw developing program, is obviously the better way to go. I don't use Lightroom, but from the ones I know and in my opinion, DxO PhotoLab excels for developing raw files (as has already been pointed out previously by Cameratose). It is expensive, but it is the champion concerning the automatic correction of the distortions of lenses and their chromatic aberrations, and one of the best if not the best for eliminating noise. It offers different good enough presets to choose from as a starting point, and you can make your own. Not complete enough for editing photos, though. ACDSee Ultimate is OK for developing raw and very good in my opinion for editing photos and with this one you can save your own parameters/presets to use as a start point as well (and it excels as a DAM for managing your media assets). Affinity Photo v1 or v2 (the previous ones to the very new and "freemium" Affinity by Canvas which I haven't nor will try) is/was limited for developing raw, it is good for editing images and very good in combination with Affinity Designer and Affinity Publisher for the tasks they can/could accomplish as a combo. Corel PaintShop Pro is very basic for developing raw and most of the correction for lenses it supposes to do are simply not done or done wrongly, though it is not bad but kind of outdated in my opinion for editing images. Capture One (which I tried when it had a limited free version for Sony cameras) is very good, but it has a limited list of lenses which distortions it corrects and is also very expensive. Concerning the rest of the programs, I don't have a clue nor can I recommend any, as I don´t have them nor have I tried any of them long enough.   Anyway, for what you wrote, you already have Lightroom and might want to stay with Adobe's program, which everybody says is excellent, though seems that most people (including me) hate their subscription scheme, and the monthly price which ought to be paid as long as being used (whilst there are programs for which you can only pay once if you want or update now and again, not necessarily every year).
