When i use my smartphone and select M video mode: i can focus by touching the screen. For some reason in M picture mode, i can't get the tap-to-focus working.
Anyone an idea what the problem can be?
Sony Imaging Edge app / Camera & lens firmware: both are the latest version. Lens: Sony FE 35mm F1.8
Edited by Yanick
