About a month ago I went on a trip to Heron Island and slipped in a foot-sized salt water puddle on a rock. The camera got semi submersed for probably less than a second around the dial and shutter button area, and it would've hit the rock there too as it now has some paint missing on the ridge to the right of the C1 button:
As soon as I got back up I started drying it off with my shirt as it was all I had on me, and everything else seemed to work fine. But, the shutter/aperture dial is giving me problems. Initially it just wouldn't work, then after a couple hours it worked for a few seconds and then starts rapidly changing whatever it was controlling back and forth whenever I tried to use it, and by itself (eg. back and forth between 1/200 and 1/250 SS). I can still use the rear dial fine. It hasn't stopped doing this, though it tends to happen a fair bit less now.
Is there a way to remove the dial and clean/dry under it, or is there something I can just spray between the cracks? I have some electrical cleaner spray but I don't know if I should be spraying that in there.
    • Hi Guys, I have a Sony a6000 bought second hand. It's working fine but the photo capture from video function in the playback menu is missing. I've updated the firmware to 3.21 from 1.00 but the option is still missing. I can now shoot in XAVCS but would like to grab still images from the video. Anyone please?
    • Some questions to help you formulate the answer to your own question: In what sense do you feel your 70-350 is lacking? What do you hope to gain from this 'upgrade'? What % of your shots are in the 70-200 range? If this % is significant, the 200-600 is not an option unless you carry two cameras or don't mind lens swapping. What % of your shots is at 350mm and potentially could have benefitted from more reach? Do you need high resolution shots or is cropping in post an option to fix your compositions? Would carrying a lens over twice as big and over 3 times as heavy have a negative impact on your photography (think of fun, mobility, physical strain, packing volume)?
