Hello
as I mention in my introduction post I do a lot of infrared picture and development
I made a video how I do the development, as I find  that develop pictures with mask or layers is easier and faster as the way to turn colors or swop colors.
The  main difference is the layer technology and that I use for the coloring the with balance slider or the level curve.
As I am a photographer and not a movie maker my video is not a perfect one.
I am sure that what is possible with C1 you can do with other programs that offer layer technology, but I have only C1
If you have question please ask here or under the video.
regards
Wolfgang
