Does the camera work properly on the rear screen? Is the problem that it's not switching to the viewfinder, or that the camera is just not working?
Have you checked that the little window which detects your eye is clean?
Does the camera work properly in A or P mode?This sounds like time to take it to a repair place.
Give us some idea of what you have tried.
Hi FWC - emergency over. Serious operator error - Oy!  It has been too long since I picked up my camera and turned on my brain. I pushed the iso up to 8000 and the shutter speed bro there are in increments but always going higher instead of lower as every photographer knows to do in low light situations. What a maroon I am.
That's the best thing about digital cameras.  Whenever you use it, you have to bring along the 200 page, two pound user manual in order to get it to do what you want it to do.
And by the time you find the instructions that you need -- on page 87-89 -- either the subject has disappeared, it starts raining, or the battery needs charging.
