Hello.
I have a A6400 I use to shoot my local sports club activities. I like to create a 'cinematic' video of the day's sport and take still photos for the website. I am struggling to find an efficient 'hybrid' workflow using my one camera, and I hope you can help.
I like to shoot in a 'manual' when taking videos/photos. I need help finding a quick workflow to switch between the two during the heat of the action!
Current 'default ' Workflow
Video
  • Turn dial to 'Filmstrip' or S&Q
  • 4k - 25p 60M
  • Shutterspeed fixed at 1/50 {double frame rate for cinematic look}
  • I use a variable ND filter to adjust the exposure
  • Aperture - manually adjust to suit
  • Picture Profile 7 - SLog 2 (colour grade in Edit)
  • Edit and colour grade in FCP
  • Turn the dial to M
  • Capture in RAW
  • Shutterspeed 1/800 {or more for sports action}
  • Aperture - manually adjust to suit shot
  • Iso Auto Min SS 100 -800
  • Turn ND filter fully open
  • Picture Profile 2 - Standard setting for still images
  • Shoot in Raw Edit in Lightroom
When you change the dial from 'filmstrip' (video) to 'M' (Still photo) it keeps the 'video' settings for SS Aperture. Thus I have to spend a few minutes changing from my preferred video to my photo settings.
I presume I need to be making better use of the 'MR' or Custom buttons to be able to switch quickly?? I have played around but I need help to make this work. Or is there a trick I am missing?
Has anyone here got a good fast-switch video/photo workflow that works well for them?
Thanks for your help...
Using memory recall is best way for what you are doing.
For a6xxx series, here is how to do so from Sony site: https://www.sony.com/electronics/support/articles/00203863
Basically
Setup all the settings you want for video
Then proceed as "Save your settings to memory" in the link and set it to either number - from 1 to m3
Now whenever you want to use these settings, just turn dial to MR and then select the number you assigned the settings for.
Repeat for photo.
If you are in MR and you are changing settings they WON'T save unless you do memory recall again, for that same number after doing these changes.
    • Thanks. Both dials front and rear do not work and the camera is now in the repair shop.
    • Hi. tried this one. I have the same problem and read your post. I tried everything until this. it worked.   LuckySn0wMan •4mo ago•Edited 4mo ago   I've just had exactly this issue recently on my Sony A7r2 and successfully resolved it. I bought this camera used, so looks like the previous owner of the camera tweaked it's firmware to unlock additional languages. These tweaks caused this issue after the camera spent significant amount of time without the battery installed. Note that on ny camera the OpenMemories tweak app is not installed, so I used the pmca-gui PC application to change tweak settings of the camera firmware without the OpenMemories in camera app. So my sequence of actions to fix the camera: Install the battery. Connect the camera via micro-usb cable to your windows bases PC. Power on the camera. It should start in mass storage mode. Download the pmca-gui-v0.18-win.exe executable from the official github page: https://github.com/ma1co/Sony-PMCA-RE/releases. On the Camera info tab press the Get camera info button just to test that the app can successfully detect the camera. Go to the Tweaks tab. Press the Start tweaking (updater mode) button. The Updater mode tweaks tab should popup. Camera display will be completely black and the buttom right LED will be on. Select the Unlock protected setting checkbox. Uncheck the Unlock all languages checkbox. Uncheck the Unlock protected setting checkbox. Press the Done button. Once the app applies all changes to the camera firmware, exit from the app and power off the camera. After power on the camera should start working as usual. As additional info: My camera had the following tweak settings during the gray screen problem: Disable video recording limit: not selected Unlock all languages: selected (possible cause of the bug) Enable PAL/NTSC selector & warning: selected Enable USB app installer: not selected Unlock protected settings: selected After my changes that helped to fix the camera power on gray screen: Not selected Not selected Selected Not selected Not selected
