Sony A7 iii Diopter won't work
Hi all, I dropped my A 7iii on concrete. It hit lens first and busted the lens. The camera still works but the viewfinder is blurred. The diopter doesn't do anything to adjust. Has anyone had this happen or know how to fix? Thanks!
